new break lines
fmichaels
i'm looking at replacing the original brake lines with the flexible pipe set sold by Moss. Has anyone installed these and are there any known drawbacks. My only concern is the look and fit. Moss says the fitting are compatible to the original.
I installed them, and they fit fine. They say you can bend them by hand, which is true for most of them, but for some of the sharper ones near the master cylinder I borrowed a tubing bender. Use the old tubing as a template for bending the new stuff, and you should be fine.
thanks .. i'll probably go that route and let you know how it went.
