Tullamore
I just picked up my Sprite on Sunday and have been working to get it in running order. Today I finally got the engine running and decided to make sure the trans worked before I had worked on the brakes, well that was a bad idea I ran straight into a concrete wall. Don't worry it just bent the bumper in a little, I was able to pull it back out.
I got the brakes working after doing a little bleeding, I think I still need to bleed them more though because it takes some pumping to feel pressure on the pedal.
Anyways I am completely new to this engine (1275) and I am not sure how to get the dual carbs tuned and set the idle speed.
My car also has had the rears converted to wire wheels and I will need help trying to identify what kind they are should I want to get a set of all 4.
