benjaminabby04
A while ago I posted a note on the negative camber that my 74-Tr6 is showing. What I have been able to access based on the great advise of all is that negative camber should not be, and if so, it should be ever so slight - you can't tell. Mine - you can.
I have replaced the shocks, and springs. As well I took it to an alignment specialty shop, and they corrected as much as they could by removing "shims" - and I now have no more shims to remove.
According to my very trusty mechanic ( who is the local authority on British cars)bushes are fine, Any suggestions on what to do now? Is removing shims the appropriate correction? I am beginning to think that the car in it's history has had an accident. I am thinking of taking the car to a body / auto repair shop to see if they can spot anything as a result of an accident and know how to correct. Thoughts please
thanks Don /ubbthreads/images/graemlins/cheers.gif
