jhorton3
I'd never been happy with my HS2 carbs, just couldn't seem to get them right. I was contemplating a conversion to Mikuni HSR 42mm carb, but that's another story. As a last resort I decided to get new needle and seat By the way these were rebuilt carbs I acquired a few years back.
Pull the front float chamber apart and the needle looks like a viton tip, which is the type I bought. I replace it anyway. By the way it'd been three weeks since I'd run the car and there was about 1/4 chamber full of fuel.
Move to the rear carb's chamber. Chamber nearly empty of fuel. Pull float and look at the needle. It's a flimsy plastic bit with a weird shaped nose. Go to remove the seat and it's a larger diameter size than what was in the front carb.
Now it's all back together. I fired it up and just at idle and revving in the driveway I could tell a difference. I've still got to tidy things up before a test drive.
