TR4nut
I'm rebuilding a 4-syncro od gearbox originally from a TR4 for use in my TR3A. I'm at the point of reassembly, and just noticed an issue with the input shaft:
One tooth has obviously broken off at some point, maybe from trying to go into 4th gear without a clutch, or simply dropping the darn thing in a previous rebuild. No metal remnants were detected when I tore it down.
I'm leaning pretty strongly towards using it as is - only one tooth is missing, and there remain 29 others in good shape. Anybody have a counter thought that this is a bad idea and I should source a replacement?
