bravenrace
Hi,
I'm new here and new to British cars, although I use to be a professional mechanic, so I'm pretty good with cars in general.
I recently bought a '74 TVR 2500M. I'm sure you all know that this car has the Triumph TR6 engine in it. It currently barely runs, and I haven't spent much time at all on it to correct that. I'd like to educated a little more before I do.
Here's the symptoms. You have to crank it forever to get any fire at all. Starting fluid doesn't seem to help. The colder it is, the harder it is to start. Once it starts to try to fire, it still takes many tries to finally get it to start. Once it starts it sputters, occasionally backfires, and occasionally revs smoothly and freely for brief periods of time, then it goes back to sputtering. The misses are bad enough that you can't really drive the car at all.
I did take it out on the road the first day I had it. I warmed it up for a long time before taking it out (it does run better when it's warm, and the choke on each carb is working). I drove it down the road about 1/8 mile and it died like I had turned the key off. It wouldn't restart. I checked for spark and it seemed like it wasn't getting any. It also seemed like the carbs might not be getting gas, so I put some more in. After that it kicked a couple times, but still wouldn't restart. So we towed it back to my house.
I had my son spray starting fluid in while I tried to start it, and it would fire and then die once it burned all the starting fluid. I checked the spark again with a tool that is installed inline in the coil wire and is clear. There was an arc, but (at least compared to other cars I've seen) it looked very weak.
That's as far as I've gone with it. You might notice that these symptoms seem to vary with the situation, and you are right. Its also seems unlikely to me that it has boht ignition and fuel problems, but not impossible. So before I spend a lot of time on this, I thought I'd pick your brains in case there are any common reasons for this problem or peculiarities with this engine that might call for special troubleshooting procedures. The reason I've titled this post as needing help with the Stroms is that according to the previous owner, two separate British car repair facilities told him that there was something wrong with the front carb, but he didn't know what.
Any ideas? Sorry for the long post.
Jim
Jim
