Jim_Gruber
I put Bugsy back of 4 wheels today to tighten wishbone bolts and lowered him to the ground. LF no problem, Right Front no Problem. Right Rear, tighten up, crap the tang slipped out of the slot, loosen and reposition No problem, tighten down and double check the back tang and aw crap it's all out of position and bent to He_l and back. So everything and I mean everything is all bolted back together. This was the final step. Ideas on how to fix easily. I can drive the bolt out no but thinking since spring is under tension I need to remove the spring before I try and drive out the wishbone bolt to replace or straighten out. Thoughts gents, and the day was going so well. Should have stopped while I was ahead and not have gotten tired to think this out in advance of cranking down the bolt.
