Spitfire Need help placing date and point of origin
Tony P
Member
Hello everyone, I am restoring a Right hand drive spitfire 1500. With that said I need help placing the correct year of the car, and the country that it was manufactured for. It is registered as a 1976 in California, but I believe it is a 1975. I tried locating it in the UK but was told that it may have been made for the Australian market. The Vin # 104501 FH that is how it appears on the VIN plate on the left side firewall. The frame also has a number on it but it is quite hard to read, I am working on trying to get it shaded in so it can be read.
I would appreciate any help with this or at least a direction in which to start my search.
Thanks
Tony P.
here is a listing from the Spitfire database i found...your car vin # is very close to this...Rimmers list the FH prefix as UK spec cars 1974 to 1979
1977 FH 104508 L Red Porta Westfalica, Germany Withheld by Owner Request
Thanks for the info, the part I do not understand is the FH is not o prefix on my car. The letters are stamped after the numbers 104501 FH does this have any significance on the LHD or LHD?
tony,
look around the windscreen for a metal tag. if it is still there it should have the commish #, also...good way to double check the number
usually an L follows the number for LHD
O follows for overdrive
U for U.S. market
similiar to the older TR cars
Usually seeing something like "FH" as a suffix indicates that it is a BODY number rather than a commission number. Exactly what plates are on the car, where are they and how do they read? Perhaps a photo?
EDIT: In rereading, I see you say it's on the LH side of the firewall. Is that number on a small painted plate by itself?
