Coyote1
I have to make a LEVER for the throttle and need a measurement in order to drill the holes in the correct place. Specifically, I need to know the distance between (A) the rod against the firewall that goes to the gas peddle and (B) the throttle linkage rod from the carbs that attaches to the LEVER that connects to the gas peddle rod.
Hope this does not confuse you as much as it does me.
Thanks
Larry
Thanks
Larry
