well, one step forward, two back. I needed to connect the cigarette lighter so that I can use the GPS when I leave for the 50th. While I had the console off, I replaced a lightbulb in the hazard switch surround, and replaced a fuse in the "keep the radio station memory" line. Put it all together and now the signal lights and the tailights are on permanently. The hazard lights still work and the headlights. any thoughts?
Also, if you put a battery cut off switch (negative ground) on the car, does it matter which side it is on?
Finally if someone has a spare MOWOG, my fingers are just too thick for this.
Quick advice needed though. am off to lunch (not out to lunch) and will check back later - thanks all!
