TR2/3/3A Mystery object in my cylinder head water jacket ???
karls59tr
Bronze
Cylinder out of the car and on a bench. Looking at the two pie shaped openings for the water jacket on the underside at the back of the block I saw a what looked like a piece of wire maybe less than 1/4" wide and 3" long. I tried to fish it out with the the needle nose pliers and broke a small piece off....see picture. What is is that and what's it doing in there? :smile:
To be clear, this head will be crack checked by a machine shop?
Bob
Bob I will get it crack checked when I take it in to get the head skimmed? Could you give me your thoughts on the new thread I started about the valve rocker shaft collars and worn pedestal tops? Thanks Karl
I also found a piece of wire inside the water passage in a TR3A head. My piece was 6-8" long. Not solder and no idea why it was there.
Charley
Be surprised if it’s solder then as that’s very soft and pliable
You just don’t want bits of it getting to the water pump or thermostat
Perhaps a bit of rod that broke off when someone was cleaning the waterways in times past.
I thin your right about a rod that someone used for cleaning.I tried snapping the long piece with the needle nose pliers but no luck. Not sure if you saw my other two posts. One about 3/8 valves and guides and the other about the valve shaft rocker cap? Your input there would be greatly appreciated. I'm on a budget and would like to just get the car on the road for the rest of the summer by getting a machine shop to skim the head and resolve the head gasket issue then do a full cylinder head rebuild in the winter.
Charley
Charley I wonder if back at the factory those many years ago someone was trying to knock out a stuck piece of casting slag with a piece of wire and the whistle blew for tea time and he forgot it there. :smile: Karl
That makes about as much sense as anything I could come up with.
Charley
You are obviously anxious to drive the car, but I would do a full rebuild of the cylinder head at this stage, so that everything is "right".
Have you done a cylinder compression test yet?...Checked the combustion chamber volume?
Ah yes to do it right. Unfortunately at 76 years old with limited resources at this point in time I must do it this way. Cylinder compression is good and valves actually look OK.
I seem to remember seeing something somewhere about the casting sand having some metal bits placed in it to reinforce the mold during the casting process. I don't think it was Triumph specific. Did a google search and found instances of people finding what looked like welding rod in Chrysler slant 6 engines and then this from an AMC forum: > Welding rod in water jackets <
Ah ha. Mystery solved. Rod used to support mold in places during casting kind of like rebar used in concrete. :smile:
Karl I think in your heart you know what you need to do, want to do and will do.
And that its right for you. I am late to the party on where your car work originated ? Was it running without significant issues before ? If so I think Get it skimmed at a good shop as minimum as you can and put back together rockers, pedestals and all. With a good annealed copper gasket to suit the head thickness.
Just my 2 penny worth.
They are quite robust engines and quite forgiving of tolerances.
