The rear SU HD 8 on my Series 1.5 E-Type is leaking through the jet when the fuel pump is on. A stream of gasoline about three inches high comes from the jet when the needle/piston/chamber is removed. The other 2 carbs do not leak and the fuel level in them is correct. Most of the typical culprits have been checked: float level correct, float needle/seat replaced, float is correct weight and has no leak when placed in hot water, jet/diaphragm replaced, float bowl overflow pipe is clear (no leaking through the overflow), float needle lever pivot adjusted, many expletives directed at the problem area.
Recently I let the pump continue and the stream of gasoline stopped after about 10 seconds during which about a half cup of gasoline came out through the jet of the rear carb and none through the other two. The gasoline level in the jet is now about 1/16 inch below the bridge in all three carburetors. I have no idea why it stopped leaking. I assume the float bowl is full and the needle is closed. What I don't know is what will happen when the float chamber becomes empty after sitting several weeks. For example, it may put another half cup of gasoline through the rear carb before closing the needle; this is a bit too rich for a typical cold start!
Does anyone have suggestions for what might be the problem?
Thanks for your ideas.
billca
billca
Hi Guest!
