So after a Sunday drive I parked the car and later in the evening drove it to the barn to put it away. It stalled with a tad of sputtering before I got there. Knowing this wasn't a one time issue I let it sit and it started, ran fine but sputtered and stalled again. OK probably fuel pump. Not such a wild guess as the points clicking seemed to be a bit "different". The pump didn't seem to run for as long before stopping because pressure had built up. I pulled the pump out today and sure enough when I ran it on the bench with the inlet and outlet opened it would suddenly stop unless I tapped it. I cleaned the points and the screen; it still did it a couple of times. I restarted it again and from that point on (pun intended) it seemed to run fine and I couldn't get it to fail. My question to those wiser than me is, should I trust it. I don't mind banging on the wall behind my seat if it fails, but there are plenty of inconvenient times that I wouldn't want to be burdened with doing that. Plus my wife will make fun of me (perhaps rightfully). It is about 6 or 7 years old, has the latest diode installed and the points actually looked OK after I touched them up. So, any suggestions other than dirty points as to what can cause this? I'm pretty sure it won't act up if I try to make it but....do I trust it. I will probably buy a new solid state unit as I've been meaning to have a spare. Glad I sold my airplane. The repercussions of fuel system issues can be relatively unpleasant.
