I believe the shop manual calls for the car to be timed at 6 or 8 BTDC at 800 RPM. I set them for a max advance of 32 to 38 degrees depending on the cam. That's a crazy state you live in. Here in Mass, they just did away with the smog part of the inspection. Any car pre OBD2 is strictly a safety test. OBD2 cars get plugged into the state computer and tell it if they pass or fail. Basically any code and you fail. A buddy of mine failed because the computer says the air bags are deployed. They are not, nor have they ever been. The GM dealer can't seem to fix the problem permanently, so every year it's back to the dealer before inspection time.
