I posted earlier about a source for rebuilt engines, but I have done some further investigations since then, but I still am stumped about the source of my problem.
Some background: Last week, my father (TR3 owner from 1958 until 2000) and I were driving my TR3 and all of the sudden a loud knocking was heard from the engine. We didn't see anything and limped a mile home.
Originally I though it was the transmission and I pulled it and started the engine, but the noise was still there. I pulled the clutch disc and the noise was still there. I pulled the oil pan and didn't see anything out of the ordinary. No metal fragments in the pan.
Here is where I get stumped. With the spark plugs out of the car, the flywheel turns smoothly when the starter is engaged and there is no metallic hammering. When I put the plugs in, the metallic pounding comes back. In addition, when the plugs are in and the starter is engaged, the flywheel moves forward and back a noticeable amount (as seen from sitting in the driver seat). This movement corresponds to the knock.
What could be causing this flywheel motion (and the associated noise) when the plugs are in, but not when the plugs are out of the car? I think I can rule out the starter since it was not engaged when the noise first appeared.
I will truly appreciate any advice you can give me.
