DornTRoriginal
I was interested to read about someone else having a similar problem on a TR6 but mine is, ummmm well different I think.....
I just rebuilt the rocker assembly and installed it today but I could not adjust the valves and the engine was very, VERY hard turn by hand. I installed a rebuilt head a while ago, I got the head used, it had been previously surfaced and "ported" (the person I bought it from was a racer so it was kinda "tricked out" already). I am not sure how much had been removed, it was flat according to my machine shop so we went on ahead and rebuilt it and only vey lightly resurfaced the head, I did not measure it and at the time I had the work done I didn't know what I know now, darn it! Today I did a "rough" measurement between the old head and the new one and there is about a .066 mm difference between the two. It makes sense I am thinking, and pretty reasonable to believe I need to shorten the push rods. Not sure how I am going to go about doing that so any advice is appreciated on that topic.
The other option I have is to purchase new ones, which I will probably need to shorten as well... this may be a good plan based upon all the work that has been done on the head already; First, my original push rods are 5/16", although they are in good shape, according to one supplier, it is better to use 3/8" diameter pushrods since the originals are considered "weak". Second, I did install upgraded springs, valves and guides when I rebuild the head, so stronger is a good idea and will avoid or at least theoretically minimize the occurrence of a potential MAJOR problem.
What suggestions and advice do you all recommend? Here are some pictures of the situation. Thank you all very much!
