In setting up my GoodParts adjustable trailing arm brackets, I have devised an elaborate system to check my toe-in because as some of you know, I foolishly let all my bracket shims fall to the floor when I took the TA's apart. So, what I have done is install and torque the new brackets, with no shims behind them (things should be really askew, right?), then with no axles or springs or shocks installed, I leveled the TA's by using a bubble level (the car is still on jack stands), perfectly vertical. Looking through them, the differential hugs are spot on. Then, here's the good part, I installed some large 1/4" steel plates on the faces of the TA hub and drilled and bolted them flat to this surface. The plates are spot-on flat. I suspended the TA's with some all-thread to keep them in this straight vertical position. Are you still with me? Here's the good part. I used some very large T-squares and cross-measured the two opposing plates. Dang is they aren't totally square with each other! Is it possible that with my new GoodParts brackets that I might not need to use shims. This would be uncanny. Now, seeing as the two trailing arm hub faces are totally square with each other, then does this mean that I have zero toe-in! And is this desirable? Or am I all wet. It has been a long weekend and I need some good news for a change....
not that 3/8 or so matters. Drive the car to the wheel alignment shop and bring along all your shims, it will all work out.
