RTMG
Hi All,
This is indeed a fantastic forum and I appreciate all the help I have been getting. I now have a new problem - my 2nd MG TF Tragedy in less than a week of owning it. /bcforum/images/%%GRAEMLIN_URL%%/nopity.gif
The 1st one was leaky floats - which has now been resolved by replacing the floats. Since then the car started and drove fine... until yesterday evening. Tried to start it and the engine turned a few times and then the battery gave up. Here are the facts and the actions I took based on my very limited abilities:
1. Turned lights on to see if battery had any power - lights and horn worked fine.
2. Jump started car - no problem it started fine.
3. Drove car for a couple of miles and then turned engine off. Started it 5 minutes later - car started fine.
4. Drove car again for a couple of miles and then turned the engine off. Tried to start engine - wouldn't turn again. Plugged in external charger (that a neighbor had) and engine started without a problem. Charger was set to just 6 amps. Hmmmmmmmmmmm. /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
5. I then put a meter on the battery, while the car was running with lights and heater motor (this is a Mark II) turned on, basically attempting a full load. The meter read 11 volts. The Ammeter was showing negative at this point.
The puzzling thing is that the car always started with the 6 Amp charger clipped on the battery terminals the two times I tried it. I didn't really give it any time for the battery to charge as such.
So, I aksed myself if I did anything <u>different</u> the night before, and here is what I can think of:
1. I used the battery cut-off switch that was installed by the previous owner for the 1st time. I can't imagine this causing any harm?
2. I figured out how to turn the panel lights on the night before and was playing with that switch - because it intermittently turned the light on/off - seems to be a bit rough. Don't know if this switch (which seems to act as a dimmer) had anything to do with this problem. Turning off the light switch turns of the panel lights also. Again, I can't imagine this causing any harm? Specially since I used the battery cut-off switch.
So this is where I am now. Sorry for the long post, but I thought the details may provide some insight.
I am now trying to figure out if the problem is with the generator, the battery, the voltage reulator or some other component.
Your advise is appreciated!
/bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif
RT
RT
