hondo402000
went to crank the TR6 yesterday, crank,crank, crank, wont start, pull the spare plug out of the trunk, stick it in a plug wire turn over the engine, no spark, pull the coil wire and check it there, no spark, find the MSD manual, says hold coil wire to ground, find white wire going to distributor, turn on Ig switch and tough white wire to ground and pull away and you should get a spark, no spark, manual says" send back for repair" purchased a new unit 250.00, will install today, if old one is bad I will send off to be repaired and have a spare,
