Motor Rebuild
TR674
Gents (and ladies)
I've been away from the BCF for about 9 months or so now. My wife popped out number 3 last June and at the same time my TR6 was suffering internal hemorrhaging (I think it may have been trying to give birth too......probably the anti-Christ).
I was also trying to finish off some renovations to my house, so I gave up on the beast as it was looking too hard, too much going on.
After a few deep breaths I had a good look at what was going on with the Triumph motor. Oil was bubbling out of the dip stick, large quantities of oil was collecting in the air intake tube, being blown thru the rocker cover vent. When I removed the rocker cover cap, excessive amount of smoke was blowing out at idle.
General diagnosis was a broken piston ring at worst. After studying the Maintenance Manual I decided to pull the motor apart myself. Rings were worn but not broken (oil ring was gummed up solid on all pistons) and the bearings were badly pitted and scored.
I replaced the rings, bearings, gaskets etc with the verbal assistance of my mechanic. All this done in 2 weeks.
Well, I have done 1500km now and it's running the best it has done under my ownership. No oil leaks, no oil smoke from the tail pipe and no oil collecting in the air tube. So what initially looked like a daunting exercise, turned out quite well. Considering I'm a complete novice. I neglected to take any pics or record detailed info as I didn't expect the rebuild to go well. I had the number of a tow truck at hand during the 2 weeks just in case!!
Regards
Craig
Welcome back, Craig! And congratulations on number 3.
Glad to hear of your success with the TR as well. Great feeling to have done that, isn't it?
:cheers:
Mickey
:winner1: YOU for doing a great job. I have often felt overwhelmed at completing a task on my TR6, but sometimes I just step back from it for a period of time and then have-at-it!
Glad you did it.... hope you are proud cause you should be!
Craig, you may have just described what owning these cars is all about. Cheers to you for having the gumption to tackle a tough job. And, you'll always be proud that you did it yourself every time you turn on the ignition.
Also, you're now to be considered and "expert" at Triumph engineering and may be overwhelmed with requests from other owners. Be prepared! :lol:
Great work, Craig. :yesnod:
Thanks all.
Yes, I am gloating to some degree.
I did hold my breath during the 1000km 'break-in' as I was sure something was going to work loose, snap, rip, fail, explode, stop working etc.....usual Triumph traits.
Enough gloating and onto the next job.
Regards
Craig
P.S. Nick, it's 6 weeks until it's officially winter here and today is a sunny 30C (that's Celsius...).
Next job....
Enjoy the kids while they're young...
Before you know it they're all grown up and trying to "borrow" the TR
I know this first hand.
