Well, I put the engine back into the 3 last weekend, only to discover that it wouldn't turn over. I had been able to turn it over by hand easily during reassembly, but hadn't check during the last few steps. So, I started stripping things down, and discovered that my new flywheel bolts from Moss Motors were causing the problem. Apparently, they're a little too long and interfere with the rear of the engine. The Moss catalog says that I shouldn't use them with the tabs washers, but I don't know what else to do. I can't find flywheel bolts from any other source, and my originals are long gone. Any suggestions? Thanks.
