Ohiobugeye
Hi, I have a 1959 Sprite, I bought it as a rolling chassis in Feb. 2005. It had no running gear other than the differintial. I have a 948cc Morris Minor Engine that I will be rebuilding this winter. My first question is will the original Morris oil filter (that hangs straight down) fit in the engine compartment? The Sprite 948cc engine has the oil filter mounted at an angle toward the rear and extended away from the engine block. My second question is, will the newer SU H2 Carburetors fit the original Sprite SU H1 carburetor manifold ? Lastly, will the SU H2 Carbs be too powerful for a un-altered, stock 948cc engine? Any information will be really appreciated.
