More MG Skunk Works secrets revealed
Bret
Here's some more eye candy.
Just some test fitting of the various goodies.
Missing from the photos is my new Fast street camshaft an adjustable double timing chain.
Stewart said:
ahh engine pron
/bcforum/images/%%GRAEMLIN_URL%%/lol.gif
it'll be even more filth if he gets them headers Jet Hot coated... and matching that up with his billet pulleys and alloy valve cover ... /bcforum/images/%%GRAEMLIN_URL%%/eek.gif it'll be too explicit for the BCF! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Hmmmm? Looking at the pictures, any of ya'll think those old cast pedestals look out'a place. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
some what... everything else (besides the manifolds) is aluminium... looks like you need to go get some billet pedestals made to make'm match /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
The Pedestals will have to wait. Moss wants $330 for just the two outer ones. Budgets long sense been blown out'a the water.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]ahh engine pron[/QUOTE]
Stewart, I know you meant to say porn but just couldn't get yourself to type it in case the bugs are on your computer...hehehehe!!
but if he were truly "hip" it would have been pr0n... /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Looks nice. What do you have planned for a heat shield between the manifold and the header? You are using TBI type injection, no?
It looks really nice, go, go, go. This last winter I had a motor built by K Pather for a SC. After you get by the sticker shock and drive it, it really is a priceless (or maybe a pricy) drive. I truley share your pain, but ain't it fun.
Actually I'm already using Moss Motor's EFI kit.
As you can see it employs the stock heat shield. But I've been thinking about using it as a template to make new one out of aluminum to make for a cleaner look.
lol
l173 5p34kz0rz R 2 |\/|uc}-{ 4 sum p33pz
Question about your rockers: are they the ones that have been available on ebay and did you have to do any mods to them. I have a set of them and a loud tick which I suspect might be a worn rocker arm and was considering replacing them.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]to make new one out of aluminum [/QUOTE]
Will that provide adequate heat protection?
Will that provide adequate heat protection? [/QUOTE]Don't know for sure. But I noticed that our buds over at Moss make a alumized radiant barrier for their supercharger kit (PN#150-066).
The way I look at it is anything is better than nothing and I'd wager the radiant heat from the header is less than that of the old cast manifold. Especially with the positioning of the catalytic converter mounted directly underneath. My new setup will have the cat will be located further down stream, so heat to the intake shouldn’t near as bad.
Another option is to use header tape to keep the intake to help reduce the under bonnet temps.
