frankenstang57
So far I've shimmed up the spring, picked the car up a bit, but it still leans. 180'd the spring, still leans to the same side. Took the car to a competent alignment shop. (very well regarded in the high-end local racing community) Here's what we discovered, the frame is square from the diff forward. If we picked the car up by the frame in the back, using the air lift on the rack, everything is looks good. No leans in front.The droop from wheels looked even. According to the equipment all 4 wheels are facing the same direction and withing specs. I remember reading somewhere that triumph used 3 different length axles, do you guys think I may have a mixed set? We measured them with a tape measure, both were the same length. The driver's side one does have junkyard writing on it. Needless to say, all 4 of us were scratching our heads. The dif. mounts look good.
Hi Guest!
