G
Well, I have my cam "temporarily" place in the block (GP2) and I think I have it right. First, there are no areas for adjustment using a stock cam sprocket. I lined the mark up on the crank sprocket with the mark on the cam sprocket and, and that's it... What's to adjust? The first lobe on the cam (exhaust valve lobe) is pointing down and to the right (sitting on the cam and facing forward with the engine) at TDC on the #1 piston. The new chain is really tight, with much less slack than the old chain (both double rows). Do chains stretch that much? Again, there is zero way to adjust the sprocket, short of whallowing out the two mounting holes (that was a suggestion from GoodParts). I still don't have a head in yet. Thought I could drop in the cam follower and measure the rise and fall of the new pushrod with a dial guage, if that would do any good. Again, am I on the right track or is the cam in wrong? Lots of lube on the cam. Waiting for the head. Cleaned the piston tops off (bunch of carbon). Any way to polish these or just leave them with micro scratches? So many questions, so little time.....I've had a headache all weekend to boot.
Bill
Bill
