1958 Mercedes sedan, four wheel drum brakes.
Cranked up the Benz and backed out of the garage. Pressed the brake pedal and felt it go about halfway down before the brakes took effect. Much farther than usual.
Checked the reservoir - full of brake fluid.
No leaks at wheels, at booster, or m/c.
All shoes free to move in and out, no binding
Brakes still operate smoothly, no dragging or binding, etc. You just have to push the pedal twice as far down.
I thought it might be the vacuum booster, so I disconnected vacuum. Absolutely no difference in pedal travel (but of course much more effort required).
Can't figure out what would cause the pedal to have so much more free play than a week ago. Before this, pedal pressure started tightening brakes after the first 1/2 inch travel. Now it's about 3 inches. Can't imagine that the m/c free play adjustment would suddenly change so much, and the adjustment bolts are still tight. Also can't imagine the fluid would suddenly be "contaminated" with moisture so quickly.
If I "pump" the brake pedal each time before use, the free play is reduced. But pedal has to be pumped at every use, or the free play increases to that 3 inches again when the pedal is released.
Clueless in Benz-land.
Thanks.
Tom
Thanks.
Tom
