The underside of the steering column hiding the wires in the drivers footwell is sagging to the point of interfering with safe operation of the brake and clutch. It is hanging down from the right side, but seems firmly mounted from near the door side. It almost loose as if it has shrunk to the point it no longer fits, and might even be made with a particle board material.
What is the typical fix, and how is it suppose to be supported from the center console area?
Also my hood release had one of it's two plastic wings break off. I can still open the hood, but was wondering what it takes to replace the handle, or is it all one piece that you need to replace the cable as well?
TIA
TIA
