mikecyc72usa
So my 78 Spitfire 1500 has covered over 8000 miles since last March when I got it on the road after a 15 year slumber. I've had some issues, but nothing huge. Now it looks like there's a mystery cause to a squeak and popping noise and feeling from the rear end. I suspect a wheel bearing, as I got under the car and went through the driveline. All bolts are tight, no u-joint seems to have any play, diff has just a teeny bit of slack, no more than any other Triumph I'ved owned. I'm suspecting the left rear since the noise and feel is worse on left turns. I should say that I get a good clunk when I engage gear, and have a good knocking sound when slowing down, with or without being in gear. I also noticed the left rear driveshaft seems to be slightly off, as the rear wheel hub wobbled slightly when in gear while jacked up and running in 1st gear.
So, after all that, have I missed anything? Anything else I should check? The rear suspension is tight in terms of bolts, shocks, etc.
