GregW
Mine are M6x1.0. I bought two lengths, 10mm and 14mm. The picture has the 10mm installed, The cap screws only provide friction to keep the head from loosening on the 3/8" center thread. I could drill recesses in the ballhead for a more positive lock to the tripod. but I'll wait to see how it works as-is.
I would rather grind (Dremel w/cutoff wheel) the screws than drill into the head. All that's needed is a bit of contact twixt screw end & head recess point. One thread more length than total contact flush at the cap screw's head. A slight torque with an Allen wrench would cinch it in place the same way the grub screw works. I think if just "finger tight" there would be opportunity for some "slack" when panning if there's much drag involved. Just have to keep the wrench with the 'pod somehow... still need a tool, but much more convenient than that grub screw!Mine are M6x1.0. I bought two lengths, 10mm and 14mm. The picture has the 10mm installed, The cap screws only provide friction to keep the head from loosening on the 3/8" center thread. I could drill recesses in the ballhead for a more positive lock to the tripod. but I'll wait to see how it works as-is.
May need to get half a dozen 5mm Allen wrenches tho.
GregW
The last great hardware store for fasteners in Los Angeles. Culver City Hardware.Where'd you find cap screws?
Well, I aborted the attempt to make the cap screws work. On this model, the area where the screws go in has the shoulder of the column too close to the screw holes. The head of the cap screws can't be wound past that shoulder and rubber washer without grinding a semi-circular "relief cut" in the column head to allow the caps to seat.
You just need to get the correct screws for the task:The head of the cap screws can't be wound past that shoulder and rubber washer
Thought of the day-Innovative car repairs
How did the cap screws work out, Greg?Mine are M6x1.0. I bought two lengths, 10mm and 14mm. The picture has the 10mm installed, The cap screws only provide friction to keep the head from loosening on the 3/8" center thread. I could drill recesses in the ballhead for a more positive lock to the tripod. but I'll wait to see how it works as-is.
I don't see having to swap heads on the 3033 'pod, so abandoned the project here. That thing is hardly a field piece unless I would be out star tracking and I'm leavin' that up to Basil!
On the "new" Manfrotto with the ball head, the cap screw works fine. Only one set-screw. The cap screw locks the head in place, clears both the column collar and on full collapse has some space before hitting anything in the lowered position:
All good. Thanks for the idea, Greg. Much less "fiddly" to remove/swap heads.
Pazienza, bambino! First it's turtles, man. Access to west-facing beaches is a trial. Parking is a pain, most accessible places attract big sunset crowds. It'll happen but likely south of here where we have private access to some scenic areas. Englewood and Boca Grande. Friends we plan to visit some time next month.
Makes so much sense I'm embarrassed I didn't think of it long ago. Thanks again.Glad someone else benefitted.
Now looking into a way to anchor the ball head on the monopod.
What does the top of the Monopod look like ? A single 1//4 or 3/8 female for screw-in?Now looking into a way to anchor the ball head on the monopod.
Hi Guest!
