Spitfire MKII cam in a MKII '65 Spit - pros and cons
DomCasual
Member
"A guy down the street" sez putting in a MKIII cam in the 1147cc engine is a good thing to do -- a relatively cheap upgrade.
Is this really a worthwhile upgrade or is it just "doing something to tell the guys about."?
What's the upside vs the down?
...and while I've got your attention, do you vote for a 3:89 tranny or OD as an upgrade?
Peter in Charlottesville
The Mk2 Spitfire and the early (non-emissions) Mk3 Spitfire camshaft are the same, so no gain there! As to a 3.89:1 diff v. overdrive, the diff will be much cheaper and easier to source, but it will yield only about a 6% reduction in engine speed for a given gear. A typical Spitfire gearbox with OD gives you a: two extra gears and about a 20% reduction in engine speed in the top two gears.
Thanks for the information -- always good to hear from knowledgeable folks.
