VelodromeRacer
Hey all,
I need to verify the location of the mix screws for the SU carbs on my 1966 BJ8. Also, just to check, does someone know if you screw them out, or up away from the carb, does that lean the mix or enrichen it?
Can someone check their mix screw and tell me approx. how many full turns out it is so that I can check mine?
I used the Gunson colortune I bought and it is a cool item to have, but I really didn't think I was getting the changes in combustion that I should have. When I try to start this car cold, it really backfires through the carbs at least until it warms up.
Thanks
Thanks
Hi Guest!
