Dugger
After about a 225 mile drive this weekend, I found that I was about 1/2 qt. low in motor oil. I checked the normal leaking points, front seal, rear seal, oil filter adapter, pressure transmitter, etc. pressure guage, etc. There was a small amount on the oil pan, but it seemed to be leaking around the drain plug and not enoiugh to be missing 1/2 qt.
I checked beneath the car rear of the engine and found nothing to speak of, well, no indication that 1/2 qt had leaked out...well that missing oil has to go somewhere.
Since I do not have the crankcase breather valve and the hoses from the valve cover connect both carbs and the charcoal canister, I think that it may be passing the oil through the carbs. I would suspect that misting oil vapors could be drawn by vacuum into and through the carbs. I checked the plugs and they appear normal - no carbon build-up. I checked compression, 150-160 psi across all 6 cylinders (warm, but not hot).
Can you blow/burn 1/2 qt of oil and not foul plugs?
BTW: The car ran perfectly all day, did not overheat even though 90-93 degree day, no missing, no smoke (would think if oil is passing thorough carbs there would be some smoking)and the drive included small town stopping and Hwy speeds.
Anyone have a an idea?
