Missing Bleed Nipple?
jjbunn
Greetings, old friends from my days with Harold, the MGB GT :smile:
I occasionally get email questions about MGB GTs from people who have looked at my MGB GT web site and assume I am an expert - ha! Poor saps. Sometimes I can even answer them. More often than not I point them to British Car Forum.
This is one that I just received, and can't help with. I thought I'd come along here and ask directly, as it is sort of interesting:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]"I have a 68 MGBGT. Brakes suck. Act like lots of air in lines.
The place where I would expect to bleed has something called a "plug"
in it...no nipple, no way to bleed.. So I ordered new nipple bleed valves
from Victoria and I plan to replace plug with bleeder valve. (front wheels)
Victoria also sells plugs, but I don't even know what they are for. So,
I'll keep the plugs; maybe someday find a use. Cannot find any
info on Internet.
Comments?"[/QUOTE]
Any help on this will be passed on - thanks!
Julian
There are 2 holes in each caliper near each other. one gets plugged, one gets the bleed screw. The one that points most inward gets the bleeder. A bleeder in the other upward facing hole would get the plug, else a bleeder would likely touch the wheel. The plugged hole is a drilling for the fluid channel, BTW.
Peter
Many thanks, Peter!
For the future, the hole with the tapered bottom gets the bleeding screw...if there are not problems with interferance, etc.
Cheers,
D.
Cheers,
D.
Both holes are tapered and seal the same way.
Peter
Always use the hole at the top. Some calipers have a small metal ball at the bottom for sealing {no taper}.
Cheers,
D.
Early Girling calipers had a ball, but they can, and do, use the later bleeder with the taper.
Peter
