T-Series Midget door catch/lock
dfwip
Hi all-
New to forum. Finishing a ten year restoration (aren't MG's like a fine wine?) on my '73 Midget. The door catch/lock on each side is worn. Found striker plates at Moss and Vic Brit but cannot find new catches. Any ideas?
Thanks........
I may have a good used one. It will be Tues before I can get to the WH to check. Whice side do you need and what's wrong with your's.
Thanks guys.
The drivers side is ok.
The passenger side has alot of play. After door closes you can "overclose" or push the door in further by about one-half inch. No trim or sealing is on the car yet. Was kind of hoping to source new ones, but will gladly appreciate good used in new not available.
Thanks again.
If Tom doesn't have it, I do....
