Hello Spridget forum I'm visiting from the Triumph forum. A friend of mine is having some issues getting his Midget running after being off the road for a couple years. He put fresh gas in the tank,checked the timing and went over the ignition system and cleaned out the carbs. He says the engine idles good but when you step on the gas there is a backfire. We are thinking it's a fuel problem? He did say he had to give the fuel pump a rap to get it going so it's probably the contacts in the pump. I have a spare pump he could try if that's the actual problem Anybody had similar symptoms with their Midget and know what to check next? Any ideas most appreciated.
