My 78 MG Midget doesn't start when warm. It starts when the engine is cold. The gas is fresh. The battery charge is fine. Plugs & wires are good. The engine sounds as if it wants to turn over. I don't believe it is a starter problem. I've had starter problems before on other makes and this current issue doesn't appear to be the same.
Has anyone encountered anything similar?
Thanks.
Thanks.
