tosoutherncars
Well, the cooling system seems to have taken a bit of a dump recently... still holding pressure, but running very warm (3/4 or higher on gauge). Could be a number of contributing factors...
1) the 'emergency fix' rad cap I have at the mo' is 16 lbs. Shouldn't this be more like 5 lbs?
2) new water pump. (brand new, looked fine)
3) new thermostat... supposed to be 165 deg., didn't check it before installing. Moss supplied.
3) rad and block recently flushed. (maybe it disturbed some sediment which is now blocking up the rad?)
Got some sodium citrate today, will clean and flush, and perhaps swap back in my old (known good) t-stat just for good measure.
Assuming all that doesn't work... what's the current consensus?
New stock rad?
Recore existing rad?
Rad swap? (if so, info / details / pics for a 1500?)
On a high note, the engine smokes less and less, I think the new rings are seating.
New stock rad?
