Steve_S
MG owner here. Sorry to intrude, I'll just stand by the door and not sit down. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I thought you Healey folk might be able to offer some advice. I recently acquired an MGC with a built-up engine, running triple webers. I don't know much about this engine and I know nothing about webers. I understand the engine isn't identical to Healey units but they aren't completely different. Here's my question...
I know my car is running very rich, one reason being the plugs are all sooty and black. However one plug, number 5, is light tan. What would cause this?
I would assume both 5 and 6 would be the same color. I don't know these carbs at all as they are still new to me, but I thought each carb feeds two cylinders. If that's the case, how would only one plug be light tan and the other sooty black?
Other info...
The car runs well although it idles high when warm (cold idle 700, warm idle 1300-1500). There is an occasional "puff" for lack of a better description, as if the engine missed. It happens mostly at idle, and sometimes there is a hesitation at speed when the throttle is feathering between idle and accelerate. Nothing serious though. There is also occasional run-on after shutting down when warm.
Specs on the car and engine can be seen here:
https://www.mgnuts.com/mg/mgcgts/specs
Any input appreciated!
Other info...
