eschneider
Thought I'd run this by the MGB experts before testing the waters with both feet, especially since I'm neck deep in the water anyway.....
Here's the story.... Customer comes in with floppy visors. The visor rivets are loose, so I drilled out the old ones, and popped a couple of new ones in place. THOSE came loose, so I drilled the new ones out, and the drill bit hit the corner of the windscreen glass and cracked it.
So now that I've purchased a new windscreen for the customer (and rubber seal, and the frame-to-body gasket....) and disassembled the frame assebly using a can of PB blaster, a jewller's torch, and 3 busted screw extractors.....
I really don't want to use rivets again. On a new frame, I could have prbably threaded the holes and used a threaded fastener, but the holes are enlarged - if not from the rivets being sloppy, then from some dope drilling the old ones out over and over again..... *cough*
So here are my thoughts about how I might sink deeper into the hole I'm digging:
1) use a 10-32 screw and thin nut (the back side of the pop-rivets protrude into the frame anyway....)
2) attempt to use a heli-coil insert into the frame, maybe with a build-up of epoxy on the back side
3) use rivets again with panel bonder to glue the visor brackets in place (won't work for the rubber bits, though)
Hi Guest!
