MGB MGB Rear Spring Lubrication ?
MikeH
I'm going to go through my rear suspension soon, and the Bentley manual mentioned some fluid that i haven't heard of for the rear spring leaves. What does everyone use? Thanks,
on the rear leaf springs? or on the bushings for the rear springs?
I would think that if you had grease zerks on the bushings then grease, but I haven't seen any zerks on my rear suspension. I reckon if you rebuild the leaf springs then some white lithium or axle grease should be more than sufficient.
