Monark192
Now that the diff clunk is fixed, it is time to move on to the next item on the project list. The car will pull to the left when you are on the gas, straightening up when you lift off. Which end of the car should I look at? Could it be the bushings in the ends of the leaf springs or..???
I agree with Stewart. Also but not likely, the left rear brake could be dragging under acceleration due to a bad bearing allowing the axle to move slightly forward and giving the right wheel more freedom.
