It's a pretty straight forward swap. As Mikey says, you will have to add another wire from the yellow o/d feed wire on the passenger side of the engine bay, or get the factory style harness which includes the wires for the reverse lights, as well. Engine has to come out, a longer 72" o/d speedo cable has to be used as well. Besure to go back with a new clutch to save having to pull the engine again in the near future. Make sure the tranny you get matches the speedo TPM that's in your car. And check BOTH switches, reverse and o/d lock-out, on the tranny before you install the tranny in the car.
