Just bought a 65 MGB last month. Rear brakes weren’t working well so I got into see what the problem was. I could tell someone before me didn’t put them back together right (brake shoes put in the wrong way, upper and lower springs flipped around). The manual that I have shows a picture but it’s not clear how the hand/parking brake lever goes in. I think some one flipped the left and right sides.
Does anyone have a picture that you took of one that is put together the correct way? Or can describe to me which way the hand brake lever goes in (does the “L” part of it go on the top or the bottom of the attached cross bar) and how is the 1 inch long tail section of the lower spring suppose to be positioned? I think I have everything else figured out and put back the correct way.
Any help would be appreciated, so I can maintain sanity figuring this out.
Hi Guest!
