T-Series MG TD metric tire size
Bob_Engelhardt
I am SO frickin' frustrated!! I have been all over the web (it seems) trying to find an answer to a really simple, common knowledge, question: what is the metric size for TD tires? _Including_ aspect ratio!
Not finding it, I measured my old style tires (5.50 x 15 Mich. XZX inflated to 18 psi). The section width is 162 +- 3 mm. The outside diameter is 645 +- 6 mm. The inside diameter is 381mm (i.e., 15 * 25.4).
Aspect ratio is defined as height/width. And height is (OD - ID)/2. So:
Aspect ratio = ((645+-6 - 381)/2) / 162+-3
= 81 +- 3
Then the TD metric tire size is .... (wait for it):
165/80R15 !!
Of course I could be wrong and I would welcome corrections. Otherwise let this be a defining post for anyone else seeking his metric tire size.
Bob
David_DuBois said:
I am running 165/80R15. The previous tyres were 165R15 - see my PM
Cheers,
About the "165R15" size: I thought the aspect ratio was an integral part of the metric size. What does it mean when it's not specified? (Many sites require the a-r for their search.)
And what's a "PM"?
Thanks,
Bob
Go to tirerack.com and hit the chat box...they will explain everything to you.
On the other hand, I don't know too many people who know more about TD's than Dave, and his PM is likely the best advice you can get.
Good luck,
Bruce
FOLLOW UP:
I found this Moss page that has metric sizes for a bunch of old British sports cars and explains sizes and original-metric conversion:
https://www.mossmotors.com/graphics/products/PDF/Tire%20Sizes.pdf
It claims that the TD had 5.90-15, while TD Operation Manual says 5.50-15. And my old tires were 5.50-15. But neither 5.50 nor 5.90 convert to 165 (140 & 150 resp). And my tires measured 160 - 165. So there was something strange about the old tire width number.
Buying New Tires
There is not much available. I was looking for economy tires and found Nexen and Nankang. Kumho's were not available. Many places did not have any 165/80R15's (e.g., TireRack). I bought Nexen's from TireBuyer: $59 with free shipping. They arrived in 2 days.
Bob
