GaryBeu said:Thanks ya'll. Paul...there is no glove box in this car. I'll try removing the brake warning light for the left side.
JP...the driver's door wasn't latched when backing out of the garage. Door caught on wall brace and opened a little past full and crinkled the fender. Now it catches and won't close. Also don't know yet if the hinge or something may be bent...this is NOT fun especially when we ~need~ to drive her everyday.
PAUL161 said:Just letting you know that new bottom rubber seals create a situation that most have a problem with compressing it enough to get the bolts back in and have cracked the glass in the process. PJ
Try a hammer handle between the hinge of the door and the car body and close it hard! Take hammer out and try the fit. Keep at it till it closes proper and the start the bodywork on the wrinkle.Thanks ya'll. Paul...there is no glove box in this car. I'll try removing the brake warning light for the left side.
Just FYI, you are replying to a post that is 12 years old.Try a hammer handle between the hinge of the door and the car body and close it hard! Take hammer out and try the fit. Keep at it till it closes proper and the start the bodywork on the wrinkle.
