Lots of people run 'em for years and problems may be rare - but possible. If it floods and fuel gets in the foam a backfire can ignite it. That's how Tom Bedenbaugh here in Memphis nearly melted down his Midget a while back. I use an EMPI filter on mine, since it fits an RB car nicely.
As for the backfire....try advancing the timing a little at a time. Mine doesn't like the factory specs at all - but runs just fine with it advanced. If it pings under acceleration or diesels, you've advanced it too far. I think I'm at about 15 BTDC now...
Also, by "tuning the carb" did they properly jet it, or just adjust the idle mixture and idle speed? Those are the only two things that can be adjusted on a DCOE without swapping parts. If whoever did it isn't familiar with the DCOE, they won't have a clue what to do.
Did you buy the carb used (like off of Ebay), or did you buy it new from someone who knew the state of tune of the engine it was going on?
Duhh....ignore the last paragraph - I need to improve either my reading skills or my memory! Since you bought it used, do you know what kind of engine it was on previously? If it wasn't very similar to yours, you might have to completely change the primary and secondary venturis, main jets, idle jets...pretty much everything! These carbs are VERY tunable... and that's both a blessing and a curse...
