G
OK, I took the distributor apart completely and found that some idiot (me) had lubricated the weights with white lithium grease, which jellified and made the weights sticky. Cleaned all that out and did a light lubrication.
Changed to a different plug and closed the gap down to 30 from 35 (Sport Coil).
Reset all valves (they were opened too much) with intake at 16 and exhaust at 18 (GP2 cam).
Now it runs hotter a bit but it is hot here today.
If all goes well and I finish buttoning up the car, I should be able to drive to New Orleans on Friday.
