We always used a Oberg tattle tale oil filter as first of two oil filters in the wet sump racing engines. For you that are mot familar with a Oberg oil filter its a oil filter that has a reusable microscreen filter in it. The reason we used this was to see what was being caught by the filter without cutting spin on filters apart. The first thing you begin to realize is there is no such thing as perfectly clean, debris-free motor, you always find something in there. On fresh rebuilds that's when you will se the most stuff in tattle tale filter. We spent alot time over the years looking at debris we found and identifying it, what we find most in a new engine is ring scrubbings, silicone and paper towell and shop rag lint, that's probably all you are seeing, In fact after seeing so much shop rag and paper towell lint in the filter I now use coffee filters as a wipe cloth when assembling engines because it is one of the few papers speced by the goverment to be somewhat lint free, find out later my brother in law who build turbine helicopter engines for the miltary uses coffee filters as well. Bottom line there is no such thing as no debris in a engine otherwise there would be no need for a filter and it only reasonable to think some of it stayed in the pan and didn't get suck up by the strainer screen, especailly the big stuff.
I guess my question would be what were you doing pulling the pan off a fresh motor in the first place, if the answer is to just look around and check on it, then I perfectly understand, I have the same disease /ubbthreads/images/graemlins/smile.gif
