I just installed 1/8 inch brass hose barbs in the hard plastic spacers between the carbs and manifold in my TR3A similar to the way someone else posted on the BCF quite a while back. I attached my vacuum gauge to the two hose barbs with a T-connection then a single hose going up to the gauge. See attached pictures. I just put the carbs on and have not tweaked them yet to get them better tuned. However, I wanted to go ahead see what vacuum I'm getting. The vacuum gauge fluctuated between 12 to 13 pounds of vacuum pressure. My engine is from a TR4 and I have no idea what cam it may have. The question I have is, what vacuum should the 4 cylinder engine have? Thanks!
Regards,
Bob
Regards,
Bob
