Hi All,
I was hpoing that some of you would be able to give me some pointers. Where do I start? Background first. Well I've had my 67 BJ8 for three months and have done a about 500 miles in it. It has been running ok,although it may be running a bit rich as I found the plugs to be a bit sooty. It also didn't seem to need much choke when starting from cold. Journeys have mostly been under 20 miles with a few 100 mile trips. One problem was that when going up a long steep hill in o/d 3rd or fourth under load the car seemed to lack power and started misfiring. I thought this may have been something like a dodgy coil / lead etc and was about to start fitting new ones. I did however look inside the rocker cover and was terrified to see mayonnaise like sludge. Knowing that this could be either a head gasket or a build up of condensation ?? I started to look further.
Observations are as follows:
-With the rocker cover off there was sludge at each end (enough to cover a slice of bread) but not in the middle
-there was sludge in the T shaped breather tube at the rear of the rocker cover and this extended down the breather tube from the T to the left of the engine as seen from the front.
-I took off the top hose and the thermostat and no sign of sludge at all- same with other coolant hoses, no sludge
-I drained the radiator and no sludge.
-I took off the oil filter and no sludge
-I pulled the plugs. (They were indicating the car was running too rich [next job] but has no green residue from coolant, although one of them did seem to have a trace of liquid on it.
-smoke , as I hadn't been overly looking for the telltale white smoke before I knew I had the problem I can only say that I had noticed once or twice some smoke on a warm engine when pulling away sharply in second.
When I bought the car I was going to change the oil straight away , and should have, but it looked yellowish so I thought I'd do a few hundred miles and then change it. I now know , having trawled through old posts that this was not so smart as it could be that the oil was older than I thought and is emulsifying.
-I have drained oil and water from the car and my plan was to refill with new filter and continue driving in order to try and find out what is happening.
-One of my observations whilst looking in the radiator was that it is pretty mucky and although water temp is steady I thought I should use a rad cleaning product.Should I avoid using this until I've resolved the sludge issue or not?
-Likewise on the engine, would it be best before driving again to use an engine flush product , or not?
- Are there any easy tests to tell if the head gasket is gone (apart from driving it and looking for gunk).
-If you do drive it to test it could it be that it is only at high revs / full load that the gasket is failing?
-Should I use a head gasket sealing additive before I know it is definately shot?
I know there are lots of questions but I would really appreciate any answers.
Thanks in advance Mike
